Description
Boost your WiFi signal strength on the Buildbotics Controller with this USB WiFi adapter.
The Buildbotics Controller comes with an internal WiFi antenna and if the signal source is really strong, it works fine.
Since the internal WiFi antenna is inside the aluminum enclosure of the Buildbotics Controller, the signal is significantly attenuated.
This USB WiFi adapter boosts the WiFi signal and greatly extends the wifi range for the Buildbotics Controller
